Main Menu
2zz Oil Pump Gear Change
Started by manos3003, May 30, 2017, 21:34
manos3003
Right, we all know that 2zz engines suffer from pump disintegration due to resonance frequencies doing their magic at high rpm, usually over-revving scenarios.
There is two ways to fix it; one is to upgrade the sintered gear in the oil pump with a billet one and the second is to change the crankshaft pulley with a Fluidampr or another harmonic dampening pulley spec'd for a 2zz engine. They're almost mutually exclusive solutions, and I chose the oil pump gear upgrade for two reasons:
1. I had purchased from Toyota a new pump to install
2. I had already purchased from Eliseparts an oil pump gear  s:lol: :lol: s:lol:
This is how I did it and found it the best way to replace the gear without causing damage to the Philips screws holding the pump shell together.
Apart from a new Toyota oil pump (recommended, as any aftermarket billet gear is machined and toleranced against brand new assemblies) and a billet gear of your choice (Toda, Eliseparts, MWR etc) you need the following tools and process steps to complete the job.
Tools
1x long ratchet (you'll need all the torque you can get!)
1x suitable adapter for screwdriver bits for the ratchet
1x hammer (YES! HAMMER!)
1x vice ( in a pinch, a friend holding the pump can also help  s:lol: :lol: s:lol:  )
1x the biggest/fattest Philips screwdriver bit in your kit
Process Steps
  • Start by placing the screwdriver bit on the screw head and hit it hard with a hammer until it's solidly in place.
    [attachment=2:hb6c3z6e] ia2 IMAG1562-2.JPG ia2 [/attachment:hb6c3z6e]
  • With the pump secured on a vice (or with a help of a friend holding it completely flat), attach the ratchet and rotate counter-clockwise to undo the screws
    [attachment=1:hb6c3z6e] ia1 IMAG1567-1.jpg ia1 [/attachment:hb6c3z6e]
  • Remove sintered oil pump gear and replace with billet
    [attachment=0:hb6c3z6e] ia0 IMAG1568-1.jpg ia0 [/attachment:hb6c3z6e]
  • Assemble the pump and tighten the bolts as much as practically possible (avoid damaging the bolts heads)
It's a quick job, the only tricky bit is those Philips screws holding the pump together.
I hope you find this useful. Any questions on this, fire away  s:) :) s:)
I can't recall a day when I drove my MR2 and it didn't put a smile on my face
<strike>2000 Spectra Blue Mica - 2ZZ-GE gone, but not forgotten</strike>
2002 Spectra Blue Mica K20A2 coming up
Thanks Manos!
I'll put this in the How To section
