Steering UJ Symptoms
Started by ColinC, June 3, 2017, 17:36
ColinC
My steering feels a bit vague at higher speeds around 60 plus, this combined with Toyo Proxies that seemed to need bedding in, has perplexed me for a while. I dont know if its coincidence or what to have the 2 issues together, but I have found the tyres seeming to get more sure footed so I put this down to the release agent on them, as others were reporting a similar story. Now I think the tyres are not the sole issue, I dont have heavy steering or grinding etc so initially did not think to check the UJ. I checked it today and there is a very small movement when the steering wheel is rocked so slightly, but not moving the wheels. I can feel a small knocking, when holding above and below the lower joint, which I take it should not be there. I am presuming there should be no movement at all. It is a bit rusty, but the mileage is 62K and a 05 plate so I thought it was too young for play. I am thinking I need to replace it so that's a job for next week, does that make sense?
Colin
jonty
Yes it does and that will definitely help sort it out, it's an easy job, 30 mins if you're sensible with a toolkit
Fin
Sounds very similar to mine, just before I replaced it.
The roof is down on my MR2,
ColinC
Thanks for your feedback, I have ordered the part, which will take a couple of days to get here.
Colin
ad_car_08
Where did you find the steering U/J replacement in the end?
[/size]
ColinC
Sorry for the delay in responding but there was no notification. I got a genuine Toyota part and fitted it and it did make a difference, so now on to the shock absorbers and springs, and hopefully that will also help.
Colin
