Removal of fuel filler cap
Started by wotugonado, June 10, 2017, 11:20
wotugonado
As above is it a panel off job to remove it.
I think you can get it off by removing the wheel liner. There's a bit there to disconnect the cable that goes back to the lever next to driver's seat. If you mean this bit?
On reflection you probably mean the actual outer part you open, in which case I think that might be a panel off job.
wotugonado
Ahh ok that would be much simpler, any ideas how the flap is disconnected ?
Edit :- yeah should of said flap not cap in thread title.
I've got a tte ring to attach 2nd hand with no backing tape, so was thinking of bolting it in place.
Thanks for the reply though.
MR TWO
Quote from: "wotugonado"Ahh ok that would be much simpler, any ideas how the flap is disconnected ?
Can't you use numberplate tape from Halfrauds?
wotugonado
I did both in the end with the flap left on the car.
Looks good  s:) :) s:)
wotugonado
Quote from: "onion86"Looks good  s:) :) s:)
Thanks. I quite like it too. Never really liked it shiny looks better powder coated.
