MR2 w30 FL - tires size difference
Started by FuRioN, June 11, 2017, 09:14
Quote from: "FuRioN"
Quote from: "Ardent"From memory.
Think the falks were only XL on the fronts but not the rear..
Both of the sizes are XL  s;) ;) s;)
The 86 load rated are not
The 90 load rated are.
Stock is 86
You might find a small sticky label in the bottom of glove box that specifies what should be fitted.
FuRioN
185/55/15 86 load rate are XL. 215/45/16 86 load are not, but 90 load are XL also. I bought 90 load rate on the rear and will try how it drives.
