Question about engine rebuild Stretch bolts
Started by ilovejapcrap, June 14, 2017, 22:45
ilovejapcrap
I know I need knew head bolts.
But do I need new bolts for underneath the engine that bolt the crank together ?
ilovejapcrap
Anyone
jonbill
I reused my main and rod bolts. Their diameter was still > the minimum. Can't tell you what that diameter is tho  s:) :) s:)
rod bolts: 6.4 mm (0.252 in.)
main bolts: 7.3 mm (0.287 in.)
jonbill
Quote from: "Carolyn"rod bolts: 6.4 mm (0.252 in.)
:thumbs:
ilovejapcrap
Ahh thankyou
ilovejapcrap
So if it measures less than 6.4 ok or if it measures more than 6.4 ok ?
Mine seem to measure 6
jonbill
It should be 6.4 or more. Are you using calipers to measure it? If so I think you need new bolts.
ilovejapcrap
Yes but crap calipers going to get some better ones today.
I seem to be finding them hard to buy new!
What should o search for
Thousands of them on Ebay.  6 mm is not quite believable.
ilovejapcrap
I'm talking about bolts for crank not for head Carolyn.
What are they called I'm assuming crank bolts ?
I meant vernier calipers.
ilovejapcrap
Lol ahh
I've got some verniers mate, if you haven't already replaced yours.
ilovejapcrap
It's sorted mate bottom end back together.
Head next !
You're cracking on!  The bloody head is more work than the whole of the rest of the engine.  no doubt you will march through!
ilovejapcrap
So much to do Carolyn so little time.
Christ I hope it works I've sunk some money in last week !
ilovejapcrap
P.s having a best mate who is a mechanic helps ALOT I feel like I've got a years knowledge on a week !
It'll work.  No prizes for 'quick', though.  Double check as you go.  Engines want to run.
