Electric window problem
Started by SDB278, June 23, 2017, 19:01
SDB278
So....my passenger window has stopped working. At least the window is up.
I have checked the disable switch by the ignition, and it's not that.
I can hear a relay click when I operate the switch, so I assume that the switch by the handbrake is ok, and at the relay is doing something. No motor sounds.
So I am thinking the power side (motor) of the relay or the motor itself.
All other elecs seem ok. Is there a fuse for the power side/ motor.....or is the next step stripping the door to get to the motor?
Any ideas gratefully received!
Stuart
SteveJ
Have you tried giving the glass a little gentle 'encouragement' while someone pushes the switch? There is a load sensor that stops the window if it encounters resistance (such as someone's head!!) and it may be tripping before the glass unsticks itself from the seals.
SDB278
Good idea, will try it tomorrow. Knowing my luck it will end up stuck down  :-) :-) :-)
SDB278
Nope!!! Looks like a door strip down  s:-( :-( s:-(
