Monocraft 2017 target 300bhp
Started by paul.mcgrath, July 3, 2017, 09:47
paul.mcgrath
[attachment=0:28ihz2do] ia0 IMG_20170703_094106.jpg ia0 [/attachment:28ihz2do]
Nearly finished...
2000 MRS Blue , 2004 facelift engine , Whifbitz Turbo conversion 176bhp 190lbft, hardtop ,Meister coilovers, R8 18&19" wheels, Matt brace
facelift headlights , Monocraft bodykit
paul.mcgrath
[attachment=0:2u6rbc9e] ia0 IMG_20170703_103524.jpg ia0 [/attachment:2u6rbc9e]
paul.mcgrath
[attachment=0:vvdgnzmg] ia0 IMG_20170703_103715.jpg ia0 [/attachment:vvdgnzmg]
s12vea
Nice progress
Ex TTE Turbo
Another one won't hurt  .....
manos3003
Looks good. Another Monocraft in the making  s:D :D s:D
I can't recall a day when I drove my MR2 and it didn't put a smile on my face
<strike>2000 Spectra Blue Mica - 2ZZ-GE gone, but not forgotten</strike>
2002 Spectra Blue Mica K20A2 coming up
paul.mcgrath
[attachment=1:kxiyvs7b] ia1 IMG_20170704_082058.jpg ia1 [/attachment:kxiyvs7b]
Custom made adapters by Stuart @ Watfields.com
manos3003
Quote from: "paul.mcgrath"Custom made adapters by Stuart @ Watfields.com
That's now changed your PCD. Is that 5x114.3?
paul.mcgrath
5x112 35mm width , 2 part spacer , fronts are rubbing on full lock sadly ..... trying to find a pair of 18" for the front with 225's should solve the problem ,
then lower it to suit once the Meister coilovers settle
manos3003
Interesting. See if you can post up some pictures that describe this a bit better. Looks like you might need to toy with the geo of the car quite a bit to get it there. It will be very sensitive to camber/toe setups so you might need to fettle some.
paul.mcgrath
what would you want to see ?
trial and error build as I'm a total mechanical idiot ..........
my ideas and see if its possible to be done by people that know what to do , so I'm open to any suggestions or input .......
manos3003
Quote from: "paul.mcgrath"what would you want to see ?
2 things I would want to see:
  • Profile angle at full lock
  • close shot at current ride height (as close to wheelarch as possible)
a friend who put 18" on his time attack car had to modify suspension arms heavily
paul.mcgrath
Ok , i'll sort that for you later
paul.mcgrath
[attachment=0:3mtvrkpf] ia0 IMG_20170704_180908.jpg ia0 [/attachment:3mtvrkpf]
paul.mcgrath
[attachment=0:3w3pfxek] ia0 IMG_20170704_180829.jpg ia0 [/attachment:3w3pfxek]
paul.mcgrath
[attachment=0:hzo5ex7q] ia0 IMG_20170704_180716.jpg ia0 [/attachment:hzo5ex7q]
manos3003
Hmmm you might want to re-shape your wheel arch liners slightly, doesn't seem you're fouling on the actual wheel arch from what I see here.
Could do with some lowering and check the spring pre-load is even left and right.
paul.mcgrath
Its the outside part of the tyre that's hitting the inner arch/bodywork when turning if that makes sense , liners have been removed so its hitting the arch structure.... Maybe could try 215's to help but an 18" wheel would do the job
Meister coilovers have been fitted from the group buy but no adjustment as yet
manos3003
Quote from: "paul.mcgrath"Its the outside part of the tyre that's hitting the inner arch/bodywork when turning if that makes sense , liners have been removed so its hitting the arch structure.... Maybe could try 215's to help but an 18" wheel would do the job
You might have to grind and patch-weld the arches themselves then, if you go for bigger wheels you'll need smaller profile. Don't know if your back can take the bumping   s:lol: :lol: s:lol:
You will have to adjust the coilovers to your liking, ride height and damper settings. As said before make sure you pre-load left and right sides evenly  s:) :) s:)
paul.mcgrath
Bigger ....... 18" is smaller for the front , yeh and I've had two back operations  s:shock: :shock: s:shock:  .....
I was thinking that I would have someone professionally set it up for me , other suspension bits will need to be done I'm sure after all its a 17 year old car
Leethesparky
I have the lips ground out on my inner arches and welded, so they are completely flat. 215/40/17 are the absolute max I can get on and still get full lock, they are missing by about 2mm. So if you work out the diameter of those and base your 18's around that. You will miss
MR2 mk3 2001 -- done some stuff to it.
My car thread---http://www.mr2roc.org/phpBB3/viewtopic.php?f=9&t=53643
My YouTube channel---- https://www.youtube.com/c/spyderlee
Leethesparky
You can see in this pic
paul.mcgrath
thanks for the pic , have flattened the seam as you have but your side skirt is sitting further back than mine  , more flush with the beginning of the arch , have to look into that , 18's with a 215 or 225 should do the trick and adjusted with coilovers , seems I'm collecting wheels now for a hobby ..... staggered Rotas and 2 of each Audi wheels  s:shock: :shock: s:shock:
Leethesparky
Yeah my hobby too,  I've got a collection of tyres behind my shed that rubbed lol just gave away 4.
My sideskirt does sit flush back, and it's important it does to get the lock clearance
paul.mcgrath
Its not that bad but noticed its slightly forward of yours , doors are rubbing on side skirts aswell so a bit of adjusting here and there then a full match up re-spray of doors, roof, bonnet and engine cover , thought I could get away with it but it doesn't quite match , I see in your thread you're going to build a new 1zz , have you found many forged parts in UK ? Parts I've seen are all from MWR
manos3003
Quote from: "paul.mcgrath"Its not that bad but noticed its slightly forward of yours , doors are rubbing on side skirts aswell so a bit of adjusting here and there then a full match up re-spray of doors, roof, bonnet and engine cover , thought I could get away with it but it doesn't quite match , I see in your thread you're going to build a new 1zz , have you found many forged parts in UK ? Parts I've seen are all from MWR
You can get forged parts from many tuning shops around here in the UK. Speak to Fensport and other related companies, see what they have to offer.
