Rattling airbag wire
Started by Anonymous, February 11, 2005, 08:51
I like many others seem to be suffering with a rattle from the airbag wire, which I understand is solved by simply taping it down.
Having searched many threads I'm yet to find any guidance or help with access to the wire or its location; though I must admin I've not looked at the car yet!   s:oops: :oops: s:oops:
Has anyone successful got to the wire/stopped the rattle, and how easy is it?
Andy
Take the glove compartment off (open it and pull out) and you'll see the bag with wires.
Darth Paul
My glovebox rattled as well. The solution was some self-adhesive felt on the hinge joint.
This piccy is from memory and so probably looks nothing like that!  s:D :D s:D   I also felted inside the glovebox.
That pic looks just perfect  s:lol: :lol: s:lol:
I got rattles from the hinges as well and made the same fix. Now the lock rattles, unless it's locked all the time  s:evil: :evil: s:evil:
Quote from: "Tem"That pic looks just perfect  s:lol: :lol: s:lol:
A small ring of felt on the metal U clip the lock locates onto solves this one  s:wink: :wink: s:wink:
Quote from: "heathstimpson"
Is it THAT easy  s:shock: :shock: s:shock:
Thanks!
Quote from: "Tem"
Thanks!
It worked on mine; it used to drive me nuts beforehand. Now I have the window glass taken over that mantle  s:? :? s:?
Thanks Guys
Had a go with your suggestions this morning, hopefully sorted!    s:) :) s:)
