Discs & Pads replacement recommendations
Started by swandez, July 18, 2017, 15:01
swandez
I need new discs and pads and just wondered what everyone recommends, do I stick with the OEM stock or upgrade to drilled & grooved/grooved only?
Links and advice appreciated.
The car is never tracked & used on the road only.
Get yourself on eBay and order a set of mtec discs and pads. 165 incl shipping. All four corners sorted
Also,try gt4-play. Affiliate discount and a new website to try out. He sells mtec as well
swandez
Quote from: "shnazzle"Get yourself on eBay and order a set of mtec discs and pads. 165 incl shipping. All four corners sorted
Thanks for that assuming you mean dimpled and grooved?
Yeah. Although they are available in flat,just dimples, just grooved,c-hook,drilled...
swandez
Quote from: "shnazzle"Yeah. Although they are available in flat,just dimples, just grooved,c-hook,drilled...
Thanks that's the bit I'm struggling with, what do you run? I like the look of dimpled and grooved but do they have a tendency to wear through pads quickly?
Just get plain flat.
Drilled have a tendancy to crack.
Grooves and dimples CAN make them a bit noisy.
Have had the same pads/discs on for 1.5 years at least. Just ordered another set. Dimpled and grooved again
I do abuse them a fair bit.
No cracks or anything
I went plain stock pagid discs n pads all round. Spot on.
If you are running stock power (and even if your not to a degree) stock will stop you just fine.
MisterK
Quote from: "Ardent"I went plain stock pagid discs n pads all round. Spot on.
Fully agree....Pagid Disks & pads are great for standard use and they last unlike the OEM offerings!!   s:roll: :roll: s:roll:
Davred
Yes also have pagid discs and pads which were fitted by Matt performance and recommended by him.
Do a great job and never seem to rust even after standing for a couple of weeks after a wet outing.
Europerformance do them I think.
W. Red. Black leather. Facelift wheels.Toyo T1R. Pre-cats removed. Matts TTE style chassis brace. 2003 facelift front brace, FK lowering springs, Dev keyhole covers, tte rear grille. Tanabe G-Power Medalion exhaust, JSpec nose badge, mongo's, front strut brace. Matt perf engine rebuild May 2014.
Related but slightly random.
Had two comments recently how clean and well presented my discs are.
They were fitted in October 2015 for reference.
Make sure they're OEM though. Or Pagid.
Not blueprint or Eicher. They're horrendous.
keljon
Just doing mine mtec dimpled and grooved with yellow stuff pads and Hel braided hoses with decent fluid
[attachment=0:20pmnfio] ia0 33EEC72F-5C57-4E58-87EC-40B3249B4146.JPG ia0 [/attachment:20pmnfio]
normanh
Pagid discs and pads are fine , maybe a little dusty on the pads but good very good performers.
Norman
