engine shuts down
Started by stagescott, July 21, 2017, 02:46
stagescott
my engine turns over and runs for 2 seconds then stops. I changed the MAF Sensor and nothing changed...Any ideas???
First, get a code reader and see if that tells you what the problem is.  After that, it could be loads of causes ad you probably need to have it looked at by a mechanic who can check things like fuel pressure, and other stuff that requires special diagnostic equipment.
stagescott
Thanks... No codes come up and I have an appointment with the shop next week...I'm just trying to get an idea of possibilities...Other than fuel pump, injectors, broken wire...
carolineasb
Is it not the immobilizer kicking in?
2006 (56) Blue TF300 (Newbie)<br />2001 (Y)  Silver (Oldie)
2004 (04) Black (The Inbetweenie) 2002(02) Red (Little Red Rocket)
stagescott
It turns out to be one of the coils...
stagescott
I replaced the MAF Sensor and replaced the coil. Still She turns over then shuts down. OBD code is 1300...I switched the coils around and still 1300 code... any ideas?
1300. Ecm not recv signal from ignitor.
If coils swapped and still 1300. Suggests wiring issue betwen coil and ecu.
Swapped plugs around? See if code moves?
stagescott
code stays 1300...Where is ECM located on a 2001?
jonbill
Under the plastics, left storage bin.
stagescott
Is there a way to check ECM?
ping me an email, I may have a guide that might be useful
Has it helped?
