OD of Hose tail
Started by Essex2Visuvesi, July 24, 2017, 17:45
Essex2Visuvesi
Anyone know what the OD of the Hose tail from the block in this picture is?
Esex
what engine is that. Take it not a 1zz.
25 mm
Essex2Visuvesi
Yep it is a 1ZZ
The picture was taken from the TTE Turbo install manual
Thanks Carolyn. I didn't think it was that large, so I'mm guessing I need 19MM ID hose then?
I'll go measure.....
It's a used hose that's been on and off a couple of times... best I can get is 16 mm.  The tube it goes on is 17 mm.  15 mm with fairy liquid??  Hefty stuff.
Essex2Visuvesi
That should do it  s:) :) s:)  Thanks Carolyn
need to make up some hoses for the water feed to the turbo and thats where the TTE kit splices into it.  So whats good for Toyota....
The turbo is what threw me.
Also the solid pipe is not shown for clarity
Glad you sorted that one out.
Essex2Visuvesi
Ordered some nice braided hose to run to the turbo and a couple of cheeky looking AN10 Fittings for the turbo end
