Problem fitting tte springs?..
Started by dimwit, February 12, 2005, 11:43
dimwit
Does anyone know how to stop the rear roll bar bolt (i think) stop spinning around when undoing from the suspension strut leg on the rear, the off-side came off fine though.....  s:cry: :cry: s:cry:
p.s. i've tried undoing the joint directly below on the roll bar, and thats spinning as well..   s:shock: :shock: s:shock:
hope it makes sence to the tech'ies on here....
If you're talking about the bolt I think you are, the end of the bolt accepts an allen wrench and you need to use an open end wrench (not a socket) on the nut.
exactly, what he said  :-) :-) :-)
dimwit
Cheers guys, problem solved!....  s:D :D s:D
