Oh dear - engine warning light
Started by Anonymous, February 12, 2005, 16:09
Hi guys,
Long story here but my engine warning light has come on today.
I took the car out earlier it was fine. Got back and decided to give it a good clean and polish. At the same time I decided I would clean the MAF and reset the ECU. I took the MAF out and gave it a spray then left it on a table outside to dry. I took out the 3 ECU fuses and kept them out whilst I cleaned the car.
A full clean and polish later I went to get the MAF sensor. I found it on the patio   s:oops: :oops: s:oops:  . My fault I knew it was windy but I just didn't think it would get blown off. Anyway, I put the MAF back in the car popped the fuses back in and started her up. She started fine but the engine warning light never went off. I revved it a bit and it sounds fine but the warning light is still on.
Since then I have taken the MAF back out and had a look. It looks alright, the wires look clean and unbroken. It seems fine.
Now, hope you are still reading, I gutted my pre-cats 6 months ago and hadn't reset the ECU since then. Could this be causing the problem?
Last question is, should I still drive the car? I was planning on going on a nice run tomorrow. What do you think?
Car is booked in at MrT on Monday.
Thanks for the help,
Fraz.   s:cry: :cry: s:cry:
Ok. I just went out to take the MAF out and re-clean it. Thought I would try the car one last time before hand.
No warning light   s:shock: :shock: s:shock:  . Bit confused now. It has been about 2 1/2 hours since the light first came on. Any thoughts?  s:? :? s:?
That MAF is pretty sensitive stuff...maybe you got it right and everything's fine now. I wouldn't worry about it unless you get the CEL again.
That is my guess too. I will be more careful when cleaning it next time   s:oops: :oops: s:oops:  .
On a lighter note I have noticed that my '2 is noticeably faster and seems to get on the power quicker. Definately worth the worry.   s8) 8) s8)
