replacement key fob
Started by davew, August 4, 2017, 11:29
davew
i've only got one key for my 2004 FL and the remote is dying so i need to sort one out also found out the key doesn't fit the drivers door but it does fit the passenger so i suspect it's had the door swapped at some point and they didn't change the lock over.
anyway i've seen a couple of fobs on eBay that look identical but some have a different number some are listed as B17 and another says only for 422mhz, any ideas.
 m http://www.ebay.co.uk/itm/GENUINE-TOYOT ... SwurZZNW3A m
 m http://www.ebay.co.uk/itm/B17-GENUINE-T ... Sw539Zby7H m
Markb
They look the same as my 04 with the CR1616 battery...suppose at £12.50 the first one is worth a punt....you'll need a TOY41 blank key to match it.
They key you have probably only needs new buttons fitted,worth getting repaired when you get a spare sorted.
davew
cheers i will give the first one a go ,the one i have now unlocks the car fine but you have to press really hard on the button to get it to unlock, once i get a spare i will see if i can repair this one, cheers.
