Where to source exhaust gasket?
Started by Topdownman, August 5, 2017, 16:29
I am looking for a new exhaust gasket but as it is a custom made system I am not sure where I can get a suitable replacement from.
It is a diamond shaped one as in the pics below (rough dimensions shown). A quick word with the local garage and they do everything based on ordering the part by reg. no which is no use for me!
Anyone got any suggestions please?
Essex2Visuvesi
Take a trip an independant tyre and exhaust place, they'll most likely be able to find something
wotugonado
I have no idea where you can get a pre made one from, but if your stuck you can buy the gasket in sheet form and make it yourself. About £6 for small sheet on e    bay
Thanks for the suggestions.
I will look into both ideas.
Essex2Visuvesi
Quote from: "wotugonado"I have no idea where you can get a pre made one from, but if your stuck you can buy the gasket in sheet form and make it yourself. About £6 for small sheet on e    bay
Shout if you need some of this. I have a bit you can have to make a gasket
PM me your addy and I'll get it in the post
Quote from: "Essex2Visuvesi"
Thanks for the offer, thats very kind of you but I have ordered one off ebay for an MG180 V6 which appears to have the right dimensions so fingers crossed it will work!
Essex2Visuvesi
no problem
Got A few sheets of this stuff so happy to cut you a bit and wack in the post
