SMT pump noise
Started by The Don of Croy, August 8, 2017, 16:16
The Don of Croy
Since the spring my SMT pump has emitted a high pitched whine upon first priming (after opening driver's door).
The noise has gotten a little deeper now, but the actual system is working fine - and no fault codes/EML light.
Likely cause - low fluid? Worn out bearing/pump? It doesn't seem to be as noisy in use (although it's difficult to hear much over the engine anyways).
Any further advice willingly sought - I can probably upload a recording if necessary.
Toyota Tunbridge Wells are quoting £85 for a litre can, although the parts manager had never ordered it (in 15 years)...
Give this thread a read.... probably helpful.
 l viewtopic.php?f=11&t=63201 l
The Don of Croy
Quote from: "Carolyn"Give this thread a read.... probably helpful.
 m http://mr2roc.org/phpBB3/viewtopic.php?f=11&t=63201 m
Thanks, but it doesn't say much about noises...any ideas?
I suggest you send a private message to cyclehead, as he seems to have the expertise on the SMT.
The Don of Croy
Well, a quick top up of fluid and it's back to the usual priming noise.
Result!
Anyone want to buy a 90% full tin of Toyota SMT fluid?
