Fuel Pump Click
Started by Anonymous, February 14, 2005, 21:05
Not sure whether to put this in general or problems, so I have decided here.
I keep going to fill the car up with petrol, and after about £8  has gone in on an empty tank, it clicks and stops as if saying it is full. I then stop and repress and it reclicks and stops again. It keeps doing this.
Am I doing something wrong??? Am I pumping fuel in there too quickly? Let me know of any knowledge as if it is a fault I am going to get Mr T to do it under warranty!
Thank you peeps
when your fueling the car, make sure you're not pulling upwards on the handle of the nozzle or this will happen, does it on mine and i'm sure it does on everyone elses,
bit of a bugger now mines lowered, i have to scootch down!  s:? :? s:?
So just kinda push downwards yeh?
It is annoying!
just let gravity do the work, and dont push it down or you could snap the neck, hope that helps
Thanks mate....appreciate the help.
Mynes a little bugger for it! but then its an import model so i guess i will have to put up with it  s:) :) s:)
Liz
From a little search    s:wink: :wink: s:wink:  , this thread gives some tips...
 m http://www.mr2roc.org/forum/viewtopic.p ... ol+filling m
it reads as though finbar saunders has been let loose but gives you an idea!
