ALARM ISSUE
Started by Flipside, August 28, 2017, 08:05
Flipside
Hi All.  Just went to the car and couldn't open the door with the fob.   Open with the key the drivers door opens but the central locking doesnt work.  Car will start but the alarm goes off.
Any ideas why ?
I have new batteries in the fob as I changed them 3 months ago.
Sent from my SM-G955F using Tapatalk
2001 low mileage, mods: K&N 57i gen 2, toyosports manifold and Cobra twin exhaust, unichip. Colour coded side vents and spoiler.  not forgetting the ICE Install, stock sony head unit, sony xa300 aux input, bluetooth connection, 4 channel hertz digital amp, 2 channel hertz ep2 amp, mb quart components, hertz 10" subwoofer in the bins and UD JL 6.5 in sub. Boom!
Do you have more than one key fob? Maybe try other fob, or try changing the battery again.
On the other two issues... the central locking doesn't work by using the key in the door so that's not a problem. The alarm is going off because you haven't disabled it - because the fob doesn't work.
Flipside
Tried 2 fobs both leds light on both fobs.   Both the same issue.
Even so, before you start really digging, try new batteries in one fob.  You never know how long they're been on the shelf...?
To add to Oninon's advice, the fobs have a little red led on them that should light up when you press the buttons as an indicator of battery strength/function.
Other than that there have been incidents of radio interference from WIFI routers etc blocking the signal.
Flipside
So read about interference so drove down The road and fobs work.  But they won't work on my drive. Not sure what's changed.  Must be some interference somewhere.  Is there a way of changing the signal?
The wifi issue has cropped up before.  Neighbour gets new router, key stops working.  You might try: Take the spare out.  Unplug the siren.  Drive round the corner, see if the key works.  If it does, time to track down the neighbour with a new router.  In the meantime, leave the siren unplugged?
Edit:  Missed your last post.  So there you have it.  Hopefully you will have a nice neighbour who will get the interference issue fixed.  Wifi interference is not 'supposed' to happen and is illegal, so a service provider will switch out a unit that is causing the problem. IF your neighbour is willing to make the call.
Flipside
Both fobs work away from the house.  So I'll have to track down The interference.
If I remember one of the incidents was someone charging a Bluetooth device for a visitor or something so could sort itself but I can imagine how annoying it is, regardless.
Flipside
Thanks fingers crossed it will sort itself
Flipside
Sorted
ChrisGB
Quote from: "Flipside"Sorted
What was it in the end? Or have you moved?
Chilli Girl
Quote from: "Call the midlife!"If I remember one of the incidents was someone charging a Bluetooth device for a visitor or something so could sort itself but I can imagine how annoying it is, regardless.
Yes, that was me.  It was the nextdoor neighbour in my case, charging a device up via her network!  Perfectly fine when she unplugged up!
Quote from: "Chilli Girl"
Thought it was [emoji2]
ChrisGB
Wireless doorbells can do it too.
lemans
I've had similar issue too. My key fob wouldn't work at home in my garage but would anywhere else. Must have been wireless  interference from a neighbour. It went away after a few days.
Sent from my SM-G935F using Tapatalk
Daryl
Facelift Black MR2 with red leather interior. Hardtop, rear brace, SP body brace, Mongo\'s & SP Turbo - 238bp, 220lbft.
Flipside
Not sure moved the car off the drive and it worked.  Back on the drive didnt but did later. Very odd
jonbill
I think this only happens when GCHQ are actively monitoring  your house.
They've been monitoring me for years.  Never had a problem.
