PCV Hose - the other end
Started by paulj, August 29, 2017, 20:10
paulj
Just changed my PCV valve, initially the blue smoke was worse until further investigation revealed a split in the hose.  That is currently professionally fixed (!) with a couple turns of insulating tape.
Anyway, planning on replacing the hose so the question is - where does the other end go?  I see it goes down behind the back of the engine in the general direction of the intake pipework but where does it exactly fit?
Would really appreciate some advice, a diagram or a photo from an engine out of the car.
Thanks in advance - already stretching my fingers for the expected battle with the car....
Today
In the late 1980's
It goes into the top of the throttle body.
paulj
Thanks Shnazzle!  That helps narrow it down - and sort of to one side of the engine rather than round the back which will help for access.
Today
In the late 1980's
ptennisnet
My bodge, which has been OK for a couple of years now was to get a reducing elbow with hosetails on both ends.  I then got a short length of fuel hose and fitted that to the PCV end.  I couldn't see where the end that goes down the back of the engine went and so concentrated on the end I could see.
