Radio bars
Started by nimrod, August 31, 2017, 08:24
nimrod
The bars that run either side of the radio are fixed at the bottom by 2 bolts, the silver plastic cover needs to be removed first, how is the top of the bar held, I'm only asking as I have a annoying vibration on the passenger side, if I hold it while driving the vibration stops, thanks for your advise.
paulj
They have a fixing point at the top but you need to remove the heater fascia to get at it.  There is a how to on radio fitting which will help you.
Today
In the late 1980's
paulj
Today
In the late 1980's
nimrod
Thanks for that, I thought I could not see an obvious way to do it, I did forget that the cover for the post can be removed, which has a few bolts I could check, good info when I get round to checking it.
