Brake light always on
Started by Carribdis, October 1, 2017, 12:40
Carribdis
Morning all,
Any ideas for why when I turn my lights on, one of my brake lights comes on permanently? It gets brighter when I press the brake pedal, but then never goes off. Just one side, the other one is working fine.
Thanks!
Not just a name, but a way of life.
http://i274.photobucket.com/albums/jj25 ... is/car.jpg
brettfield999
Good Morning,
Is there any chance its the rear foglight?  The switch is on the indicator stalk
[strike]2000 Blue PFL MR2 Roadster with 187K, engine blown[/strike]<br />[strike]2000 Blue MRS, 80K[/strike]<br />[strike]2001 Blue PFL MR2 Roadster 131K, 2ZZ,[/strike]<br />[strike]2003 Silver FL MR2 Roadster with 81K now daily driver, 2ZZ by Headcase[/strike]
Carribdis
Update, it's actually both brakelights that stay on. One of them had a broken filament so just looked like it wasn't on, but now I've replaced the bulbs and see it's both brake lights that stay on.
Def not the foglight switch, I double checked
Webrondek
Bad earth
SteveJ
Knackered (or badly adjusted) switch on the brake pedal. Bad earth usually causes Christmas tree lights when the indicators are flashing.
smarty72
Have you changed a rear bulb recently?
I once changed a twin filament brake/position bulb and had a similar problem.  Turned out that the bulb was defective and the tail of one filament was bent across touching the other.  I noticed when the dash lights illuminated every time I touched the brakes.
current: Astral Black FL
Ex: Forest Green 2003.
beavisrules
Wait, isn't the brake light dual filament and is normaly on with the lights?. Sounds like how they normaly work.
smarty72
Yes, it's dual filament.  A 5w filament for a position lamp and a 21w filament for the brake lamp on a different circuit.
Carribdis
So they're 2 rear lights? A separate bulb, and also 1 filament which is always on, then the brake lights s just the extra filament coming on?
