Transponder key amplifier location
Started by rokz_2005, October 13, 2017, 12:12
rokz_2005
Hi,
Can someone please tell me where I can find the transponder key amplifier? Referred to as T2 on the electrical schematics.
paulj
On the diagram it shows near to I10 (ignition switch) so you should find it somewhere in the steering column area.  If my wiring diagram is right it has 5 wires to it - black, yellow, white/black, yellow/blue and black/blue.
Good luck with the hunt
Today
In the late 1980's
rokz_2005
Quote from: "paulj"On the diagram it shows near to I10 (ignition switch) so you should find it somewhere in the steering column area.  If my wiring diagram is right it has 5 wires to it - black, yellow, white/black, yellow/blue and black/blue.
Thanks Paul. It's resolved. It's built into the coil receiver pack. Just spoke to Toyota.
