Dredging
Started by Roverv8, November 6, 2017, 20:29
Roverv8
How do all ,it cannot just be me but while in the process of removing the electric aerial
Gearbox under the rear wing after removing the wheel arch liner there it was !
A good 2inch of fine dirt build up on the inside of the sill
Other side the same
Wash out with  hose and a blow out with the air line and spray down with some gt85
DONE
good call
ilovejapcrap
I have often wondered if the plastic arches on cars actually cause more harm than they prevent.
I'm big into jet washing like hell under arches etc full of nooks for salt to sit I always feel
If you remember cars prior to plastic arch protectors you will know that the metal underside of the arch was a great place for road dirt to turn into mud with dampness which was like holding a moist sponge to the then poorly protected steel, all the necessary ingredients for rust which could be seen on many cars of that era. A blast with a hose, home jet washers weren't around then, by diligent owners helped keep this erosion at bay.
I believe the plastic arch protectors give less places for dirt to accumulate and the steel bodywork is generally far better protected now than previously.
