Bearing noise from aux belt area
Started by stchris356, November 8, 2017, 12:29
stchris356
Hello guys 'n gals.
I have what sounds exactly like a alternator/tensioner bearing noise from the belt end  of the engine, but it's still present with the belt removed!
Just wondered if anyone has come across this before?
Thank in advance
Chris.
Just going to spend an hour on the car !!!!!!!
Rattles are very common from that area. If its a rattle type noise
stchris356
It's definitely more of s bearing noise than a rattle, I was convinced it was a alternator/ tensioner bearing until I removed the belt !
Sent from my SM-G935F using Tapatalk
It could be the chain a bit loose in its guides at idle.. though that's usually more of a 'rattle'.  How many miles has she done?
stchris356
About 80k it's also a similar noise of a bad air leak!
Is it running well?  Is the exhaust manifold gasket leaking by any chance?   80k is time for a chain tensioner.  May or may not shut it up.
stchris356
Yeah it runs, no oil leaks, had the rocker cover off and all looks well. It's a definite whine. When I've got some more time I'll have to look a little deeper [emoji16]
You're not that far away from me.  You're welcome to bring her to our workshop and three of us can see if we can track it down.  The manifold gasket would be an exhaust leak (not oil)...
Ricardo
Water Pump?
ilovejapcrap
not really sure of its name maybe pulley but one of the parts the belt goes around is a wheel / disk that's just bolted to the engine, on my 77 tho engine during its strip down we noticed this was very noisy and replaced it.
its a simple job except for the fact the bolt hits suspension tunnel whilst trying to remove it so have to drop engine on one side slightly !!
Stchris says he's got the noise with the belt off.  So not a pulley.
stchris356
Quote from: "Carolyn"You're not that far away from me.  You're welcome to bring her to our workshop and three of us can see if we can track it down.  The manifold gasket would be an exhaust leak (not oil)...
Wouldn't mind a second opinion [emoji16]
Sent you a Private Message.
