MK3 Gear Cage Mounts
Started by MR2Adam, November 14, 2017, 17:13
MR2Adam
Been hearing only good things about fitting solid mounts to the gear cage replacing the rubber mounts.
But I can't find the solid mounts on their own online anywhere. Does anyone have any links or suggestions?
J03
I have a spare set here with bolts you can have for, say a tenner posted?
MR2Adam
I'm guessing it's just the four stainless mounts?
If so I'm down for that
J03
Yes 4x solid alu mounts & 4x bolts.
I'll just add that these are solid mounts from a short shifter kit, so they raise the cradle to compensate. This shouldn't be a problem, but it will mean your shift sits 14mm higher.
MR2Adam
Even better with a slight raise. Yeah I've seen other owners fit just the mounts/spacers.
Just drop me a private message and I'll have them.
J03
Will do & I'll update the thread afterwards.
J03
Payment received, cheers.
