Door sills
Started by michaelb, November 20, 2017, 21:34
michaelb
Does anyone know if the plastic door sills just pop off? Is it easy do to? And more importantly is it easy to put back on?
Chilli Girl
Yes, dead easy.  With abit of a pull, they do come away and pop back in fine.   s:D :D s:D
michaelb
Great, many thanks Chilli   s:-D :-D s:-D
Having just put mine back this evening I can honestly say it's easy as peas. There's some clips that clamp onto the top seam on the inboard side and some plastic lugs that go into notches in the outboard side and a locating peg that goes into a receiver in the footwell kick panel. Will all make more sense when you get it off.
Slip a trim removal tool of your choice under at the seatbelt end and lever it up from that end.
That's PFL at least, I can't imagine FL is any different.
michaelb
Cheers call the midwife!
Ignore the tragic mess but you can see the locating holes on the outboard side of the sill and the seam that the clips bite onto at the side of the wiring loom.
michaelb
Lol, nice mess! Yes, I see what you mean though, appreciate the pic! Thanks   s:D :D s:D
michaelb
I noticed my door sill on the passenger side is sitting over the trim that runs up the door i.e. the wrong way round, so I need to fix it!
Quote from: "michaelb"Lol, nice mess! Yes, I see what you mean though, appreciate the pic! Thanks   s:D :D s:D
That's tidy compared to how it has been previously, I spent most evenings last week lying in the footwells with my head up under the dash and half this weekend putting it all back together, once I'd replaced all the blown fuses.[emoji23]
Quote from: "michaelb"I noticed my door sill on the passenger side is sitting over the trim that runs up the door i.e. the wrong way round, so I need to fix it!
Err? I'm sure the sill trim is supposed to sit on top of all the others? Unless you mean at the footwell kickboard ?
michaelb
Yes you're right, thats what I'm say is wrong, the sill trim currently isn't sitting on top and I need to fix it
Quote from: "Call the midlife!"
michaelb
Yeah, see on the right of your pic where the side trim runs up the side of the door frame. Well at the bottom of mine, it isn't sitting under the door sill, so I need to take the sill off, press the side trim down and put the sill back on over it.
michaelb
Sorry, I realised I said it the wrong way round before! Lol
Aaah, I get you now, maybe check the trim panel behind the seatbelt is fixed properly too while you're at it? There's the fixings on the top but also two push in pegs behind the main body of the panel, the same sort that hold the side vents on.
michaelb
Ok, will do! Many thanks!
Quote from: "michaelb"Ok, will do! Many thanks!
No worries, I've steadily destroyed and rebuilt mine over the last few weeks.
michaelb
Lol, I just bought a load of stuff to add to the car. I got a tte style bar and got new front & rear spats and sideskirts! I just had all the O2 senors changed and 2 new front foglights at the weekend too!
Quote from: "michaelb"Lol, I just bought a load of stuff to add to the car. I got a tte style bar and got new front & rear spats and sideskirts! I just had all the O2 senors changed and 2 new front foglights at the weekend too!
Tidy! That trim panel has to come off to fit the style bar anyway so you'll get some practice in!
