Foxy's rear light condensation.
Started by Chilli Girl, January 13, 2018, 14:29
Chilli Girl
I'm sure this has been mentioned before many times. Some of you have drilled holes to help this problem.  Can anyone point me to a "How to guide".  With all the very moist weather we've been experiencing, Foxy's behind needs a little tlc  s:D :D s:D   Thanks,
smarty72
I cured this by;
removing the light unit;
carefully removing the plastic lens;
cleaning out all the condensation;
Removing the rubber bead / seal that runs all the way round;
Cleaning the rubber seal and the channel it sits in;
Carefully reassembling with a small amount of silicone sealant on both sides of the rubber seal.
The rubber seal on mine had green stuff growing in it which meant moisture could then pass through.  I did this around May and they have been totally dry since.
I didn't take any pictures, but it's a fairly simple and logical process to follow.
Personally, I wouldn't drill holes anywhere as it isn't necessary and could lead to further problems.
current: Astral Black FL
Ex: Forest Green 2003.
Chilli Girl
Thank you, I'm not sure I would be very good with a drill anyway  s:lol: :lol: s:lol:  I'll wait for the warmer weather and give this a go, thanks.  s:D :D s:D
