Main Menu
Fooling the Airbag light.
Started by Carolyn, April 24, 2018, 08:49
If you have 'raced-up' your car, and swapped out the steering wheel and seat-belts, this knowledge will be handy:
3.3ohm resistor in the airbag plug, and 1 in both LH and RH seat-belt plugs extinguishes the flashing red airbag light on the dash!!
Courtesy of AD_car_08
Please note,
As of May 2018 MOT regulations will require a fail if the airbag has been removed and the car is not 'significantly modified' for sporting use.
In other words if you remove the driver's airbag and/or the seat-belt tensioners you will probably need to have at least a half roll-cage and four-point harnesses installed in order to pass the MOT.
