Error code P1305 and P1310 (not running)
Started by Cabrioman, May 5, 2018, 07:36
Cabrioman
Finished rebuilding engine and had it running but it stopped all of a sudden.
Error codes are....
P1305 - ignition bank 2
P1310 - ignition bank 3
I have a few things i need to check e.g... fuses, ecu, crank sensor and if i've moved anything while working on engine bay.
I've moved coil packs around and still the same codes.
Engine starts, revs to 2000 rpm then dies.
Any other advice would be great,
Sun Out - Roof Down
Whatever the Temperature
Those two codes are electric signal codes.
Basically the coilpacks send back an "I've fired" message back to the ecu, and that's what's missing.
Wiring checks.
Coils 2 and 3 are blue and blue/white wires to ecu
Also, you checked fuses, but did you check the big momma IG2 relay?
Cabrioman
Not yet no as i am in Spain at the moment.
Thanks for the info, I'll check it out next week.
Sent from my TA-1033 using Tapatalk
Sun Out - Roof Down
