Cleaning MAF
Started by michaelb, May 22, 2018, 19:40
michaelb
What's the best way to clean the MAF sensor? I've never done it but believe it can make the car run a bit better?
dan944
Scroll down a bit to the cleaning maf section. Looooads of input on this.
Honda CR-V The Work Horse
paulj
What you need to clean is a thin wire, clean it with contact spray only and don't touch it.  There is a thicker wire with a bulb which is also worth a spray of cleaner but you haven't finished the job until the thin one is done.  It hides well into the body of the MAF.
Today
In the late 1980's
michaelb
