Access to wiring mods, ie starter button
Started by ChrisHumes, March 6, 2005, 20:23
ChrisHumes
Right, how do i go about getting part of the dash off under the steering wheel? is it easy to do, and is all wiring visible and easily altered?
thanks
GSB
Lower the hieght adjustment on the steering wheel, and then grasp the instrument binnacle between your thumbs and forefingers either side of the rev counter, and pull. It'll come straight off.
Put the steering column back up, and then remove a phillips head screw from the bottom right corner of the black panel under the wheel, and a 10mm bolt from the bottom left side. Grasp the top of the panel under the instruments, and pull. The Panel will pull off.
If you have an alarm system, you may have to gently remove the LED from its holder, and the socket for the OBDII can be unclipped from the lower right side.
