Unichip+ muggianu turbo
Started by spynish, March 9, 2005, 20:26
spynish
hi guys!
I'm sure you know that the Muggianu turbo kit has now the TUV approval. What I was thinking is what happens when you install this turbo upgrade and the unichip? Can you get more than the 168hp of the turbo or is a stupid question (as it probably is...  s:? :? s:?  )?
Thank you!
If you go turbo don't use the unichip as a piggyback, unless of course you already have one   s:P :P s:P  , there's better options (fuels the chip wars saga)
If the turbo in stock form produces 168bhp then i take it, it uses the stock ECU to control things. A piggy back ECU from there will extract the same percentage of bhp as it does from a NA, so simply adding to the psi will be an easier option, but saying that, a piggy back would then be needed after that anyway to keep fueling ang ignition in touch. It's a vicious circle!!
I'm pretty sure that 168hp is just to make it legal in countries that only allow +20% power increase. 140hp+20% just "happens" to be 168hp  s8) 8) s8)
I wouldn't be surprised if it's 168hp only on paper and something else in real life. Or if you just have to up the boost to get the real joy out of it  s8) 8) s8)
