2zz and compression supercharger
Started by michaelb, July 27, 2018, 21:19
Quote from: 1979scotte on July 28, 2018, 16:24
Go for 2zz cams and standalone if you want more power you can add it later.
This makes sense
michaelb
Ok, you've convinced me! I'll go for the 2zz with stage 2 cams and standalone ecu.
Sent from my SM-G950F using Tapatalk
ilovejapcrap
Quote from: KRAMSNEHPETS on July 27, 2018, 22:05
headcase did my one. cut an access panel into bulkhead
when putting my standard engine back in I remember thinking wish i had access from the bulkhead, would be well handy.
michaelb
Did you see the Greddy sc I was looking at as an alternative?
michaelb
How do you get round the issue of the gearbox being the wrong way round? I.e. in a corolla or celica the engine is at the front and gearbox goes back whereas in the 2 it's the other way round?
Quote from: michaelb on July 29, 2018, 14:19
The mr2 is designed to accommodate the same engine the other way around. Not an issue
michaelb
Clever chaps these Toyota folk!
Quote from: michaelb on July 29, 2018, 16:00
Absolutely! Bit of a no-brainer for them
KRAMSNEHPETS
I was disappointing with my compressor conversion in the MR2. perhaps i should have had the engine refreshed at the same time as it had done 155,000 miles. Now on refreshed engine with rotrex, thats another story...!
2004 Red edition. 2ZZ engine with Rotrex 30 94 supercharger,90mm pulley. Link Storm ECU. Charge cooler. Custom Meggalian exhaust.Uprated fuel pump, regulator and rail.840 injectors.323 BHP at the hubs. Meistier coil overs. Matt under body brace. Front and rear, upper and lower braces,list goes on...
michaelb
That's pretty high mileage mate, the engine I'm looking at has 68k on it. Out of curiosity anyone know the cost of a rebuild?
Quote from: michaelb on July 29, 2018, 17:03
1200 quid minimum
michaelb
Is it worth it though...probably?
Quote from: michaelb on July 29, 2018, 17:20
Different engine but same theory.
1mzfe.
Headcase had a rebuilt one in a MK2 noticeably better than the on in my mk3.
I would always recommend a rebuild. Wish I had it done when I bought it instead of  supercharging would be on the road now rather than sitting about in pieces.
michaelb
A rebuild should give you pretty much give you a new engine I suppose
Quote from: michaelb on July 29, 2018, 18:48
If done correctly as good as new. Maybe better if you port and polish.
Most 2zz are run ragged it's well worth doing.
michaelb
I might just do that before the conversion mate
