Brake Caliper Back Plates
Started by buzzerbill, August 10, 2018, 11:01
buzzerbill
Just had an MOT on my trusty 02 PFL and only thing was advisory on 'all brake caliper dust covers corroded'. Looks like a straight forward job to replace - whip the calipers off, remove old back plates, replace with new ones, then bolt the calipers back on.  Does anyone know anyplace to buy the new ones, or I am gonna have to go to Toyota dealer for them?
J03
Unnecessary expense & faff in my opinion, just rip/grind the old ones off & be done  ;)
tricky1138
Quote from: buzzerbill on August 10, 2018, 11:01
They're bolted behind the hubs so quite a big job to replace.
As above. just remove as necessary.
Pretty sure you can get them from TCB parts if you really want them  but quite pricy iirc.
buzzerbill
Cheers guys, looks like I'll be getting the angle grinder out soon!
frogger
It's a much bigger job than it first appears to replace the fronts.
I didn't even need an angle grinder to remove though - just pulled really hard and they came off like they were cardboard!  Most people find the same.
The rears are usually a bit more held together, and I wirebrushed my old ones and painted them insitu with primer then rustoleum, to give them a couple more years.
furbern
Replaced all mine a cpuple of years ago, and to be honest sourced from Mr T I dont recall them as being expensive. I did paint them all with a couple of coats of marine 2 pack before fitting as the standard paint seems thin.
frogger
Quote from: frogger on August 12, 2018, 01:07It's a much bigger job than it first appears to replace the fronts.
Another +6yr update.
The rear heatshields have lasted a futher 6yrs after the above treatment. No idea how as they were far from perfect!
(I've left the fronts off through this time, and when the rears do go, I'll probably leave them off too)
ucb
The front dust shields perished and broke off my 530d this year. The garage just pulled them both off at the MOT and haven't replaced them.
