Front lower control arms (LCA) bushes
Started by frogger, August 18, 2018, 11:42
ilovejapcrap
Ordered, however thanks to midlife I have them now so can crack on before mine actually arrive
Quote from: ilovejapcrap on September 10, 2018, 22:25
Fingers crossed you've got "mine" fitted before yours arrive then![emoji23]
Reading through, it appears that the Yaris ones are OK.
Does anyone have a part number so I can call the dealers?
Banana has just failed her MOT on worn lower arm bushes.
Quote from: StuC on March 19, 2019, 16:36
Thought people were going with the ebay ones
Quote from: 1979scotte on March 19, 2019, 16:59
The USA ones that @Carolyn  linked to?
Quote from: Bossworld on August 21, 2018, 18:08
Quote from: dan944 on August 21, 2018, 17:03
Just a note. Go on mr2 fb page and search for Yaris. You'll find the confirmation on there.
There's a post from 2016 saying that there are two types for Yaris, and another poster in the same thread saying they're not the same but very similar.
Quick eBay search shows there is a set with a 12mm bush and another set with a 14mm bush.
Can anyone measure which is likely to match the mr2 ones?
I don't mind having a punt to save £700+ on the mr2 ones.
Would rather order once though if poss.
Bossworld
Quote from: StuC on March 19, 2019, 23:30
I'm banned from the Facebook group for some reason so can't search it, but these are the ones I bought and I fitted to my car a few months back
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F332659560803
Bossworld
105e
Clicked on that, filled in the compatability chart, said they dont fit mr2 2000 to 2007
Bossworld
Quote from: 105e on March 20, 2019, 10:13
Without getting too far into it, that list will be based on the part number. Toyota specify different part numbers for both cars. However, the car sat in my garage at this minute in time, has Yaris arms fitted to it. Held up against each other, they looked identical. Other people have reported success with the Scion arms, which is the US equivalent of that era Yaris.
There may be a difference, there may not be. For £40 I am happy.
https://www.mr2roc.org/forum/index.php?topic=66556.0
Pay no attention to ebay.
Loads of things aren't listed correctly.
Quote from: Bossworld on March 20, 2019, 09:13
Quote from: StuC on March 20, 2019, 08:19
@Bossworld are you FL or PFL in this regard?
Facelift, 04 plate car
Does anyone know if there are any differences between PFL and FL for the lower arms? I haven't spotted anything.
Bossworld
Quote from: StuC on March 20, 2019, 12:36
I don't believe there is, though your best bet would likely be Dean or Dick given their experience of breaking a variety of cards.
The only suspension 'gotcha' I've come up against so far, is a difference in spring length on the rear depending on year. 353mm vs 360mm
@Bossworld based on your rebuilt car, I have taken the plunge. I need my car back up and running this week. The States option was not viable. Additionally if i can bolster the evidence then the rest of the club benefits too. £45 next day delivery for the pair could be a huge win!
Thanks for your support. :)
Bossworld
Quote from: StuC on March 20, 2019, 14:32
Good luck and if the car has ever lived near the sea, get plusgassing the bolts now. Not that much to undo to change them but it might take some persuasion. Couple of us documented our fun in here
https://www.mr2roc.org/forum/index.php?topic=66648.0
I also opted not to dismantle the hub, which means you'll need to use your judgement for the torque on the castle nut as you won't get a torque wrench in there with the hub attached
So ordered these before midday yesterday and they arrived 24 hours later!! Big win from Yodel today. :) :)
Thought I would throw up some photos for future reference.
Have taken the boys down to the garage for them to fit and make Banana fit for the road once more. :)
@Carolyn any chance of double checking these against the stock/Scion parts you have on the shelf?
Not really, 'cos I don't want to unwrap them.
Quote from: Carolyn on March 21, 2019, 15:24
Fair enough.
If you do ever unwrap them, perhaps you could review this.
Quote from: StuC on March 21, 2019, 15:27
Fair enough.
Happy to.
I've got some of the Murican ones but they're on someone else's shelf at the moment, they're unwrapped though so if he ever brings them back I'll try and remember to measure them.
Quote from: Call the midlife! on March 21, 2019, 15:39
You realise that this will happen 5 seconds after you have taken the car off the axle stands, to complete the job! ;)
Quote from: StuC on March 21, 2019, 15:56
Nah, I've had them since last summer, bought them as shelf parts while they were at (what was then) the best price for the part. No need of them at the moment, touch wood..[emoji23]
