Aerial issues
Started by Spruce1990, August 24, 2018, 10:47
Spruce1990
Me again! This bargain MR2 is turning out to be exactly what I paid for! So now the aerial is stuck. For a short while, the motor whirred but couldn't move the aerial without assistance. Now it seems the aerial doesn't move at all (I imagine that I could push it in, but I don't think it'll come out) The aerial does have a slight bend to it and I have a feeling that, when it had first got stuck, some wd40 might have sorted it but I think its past that now! As the motor still whirrs (annoyingly, but also is there a chance it could overheat and burn?) I'd like to disconnect power to it. At the same time, I'd like to replace the huge aerial that makes it look like an RC car with something more subtle! Any suggestions? I've found a few things on the forum about stubby aerials not working too well?
Justin.D
Stubby aerials need some sort of booster or amplifier - full length ones like stock on the MR2 doesn't. Many who have fitted the stubby ones haven't fitted the booster so that's why a poor signal
When I first got mine I had the same issues as you. I removed the aerial motor (there's a How To, I'll edit the link in) and replaced the shaft (I'll find a link to one)
Edit - Aerial assembly - https://www.ebay.co.uk/itm/Toyota-Power-Aerial-Antenna-Hilux-Surf-96-05-4Runner-AM-FM-Radio-Mast-Tooth-Cord/162943414876?fits=Car+Make%3AToyota&epid=0&hash=item25f02f325c:g:8NAAAOSwn3Vap5IY
How to - The pics have suffered the photobucket scandal but hopefully will give an idea - https://www.mr2roc.org/forum/index.php?topic=30031.0
Click for my Readers Ride
paulj
If you just want to stop it working while you work out options, the aerial motor relay is a small box under the drivers side compartment bin.  Pull the wiring out of it and everything will stop!
Today
In the late 1980's
Justin.D
I may have given a duff link above - My aerial has 6 sections, the one in the link has 5. I don't know if this makes a difference, but better come clean
One with 6 sections here - https://www.ebay.co.uk/itm/BIG-SALE-GENUINE-OEM-AERIAL-MAST-TOYOTA-MR2-MK2-5-REV2-5-ROADSTER-ON-BACK-WING/113218421696?hash=item1a5c5803c0:g:kmYAAMXQ3kRQ8Jtp
Spruce1990
Quote from: paulj on August 24, 2018, 17:07
Is it literally the only wiring in there?
Spruce1990
Quote from: Justin.D on August 25, 2018, 08:58
No worries! I hadn't got round to looking at the links yet, so no probs! Thanks for your help
paulj
Quote from: Spruce1990 on August 25, 2018, 12:03
As far as I can remember, yes!
Today
In the late 1980's
Spruce1990
Quote from: Justin.D on August 24, 2018, 12:48
https://www.amazon.co.uk/Car-Aerial-Antenna-Booster-Amplifier/dp/B004SO5FUE/ref=cm_cr_arp_d_product_top?ie=UTF8 is this the type of aerial booster I'd need? Looks a bit ebay "performance" chip to me!
