Spark plug socket recommendations please!
Started by cptspaulding, October 7, 2018, 22:48
cptspaulding
I have 2 spark plug socket & have the same issue on both.
I put the new spark plug in, then it's a lottery when I go to retract the tool. Either the ratchet & extension bar come off leaving the socket wrapped round the plug or the socket comes off BUT leaves the rubber gripper behind in the plug.
Perhaps i need recommendations on extension bar too. For info, the plugs on the 2zz sit deeper than 1zz & for further info I use 3/8" ratchet.
All recommendations & advice appreciated.
Sent from my KFGIWI using Tapatalk
I use the socket that came with my Halfords advanced set. Plug always sticks nicely and I can just use normal ratchets and extensions
moredun
A little silicon will secure the rubber to the socket, this will prevent leaving the rubber on the spark plug.
Also a little washing up liquid (or other type of lub) smeared inside the rubber prior to inserting the plug, will prevent the socket "sticking" on the plug.
Sent from my keyboard using PressKeys
delhusband
Quote from: shnazzle on October  7, 2018, 22:54
+1, that's the one I've got
I use a standard 16 mm long socket and remove the plug with an extending magnet.  I never liked rubbers in sockets.
Bossworld
I bought a cheap one off eBay before I realised there was on in my Halfords set.
Either way, I just push the rubber firmly into the socket before using it (each time) and it's done the trick.
