Clutch replacement - what else?
Started by Justin.D, October 24, 2018, 10:25
Justin.D
As titled really, clutch needs replacing, is there anything else advised to do at the same time?
I'm thinking gearbox oil (mt90?). Any other suggestions?
Click for my Readers Ride
J03
Genuine or decent quality release bearing  :)
Brizee67
Some people like to replace the driveshaft seals too
Ensure flywheel is flat and smooth.
A light skim.
Justin.D
Quote from: J03 on October 24, 2018, 10:28
Got the clutch - release bearing comes as part of the kit. Thanks
As Jason suggested, inspect the flywheel.  I seem to recall that you've been driving with a slipping clutch for some time, which will result in a glazed surface.  That tends to make a new clutch a bit 'bouncy'.
If the budget doesn't run to removal and a very light skim, then break the glaze with some 250 grit wet&dry.
Justin.D
Quote from: Carolyn on October 31, 2018, 09:02
Thanks C. The lads in the garage I'm taking it to will look after me (Former pupil, and I've sent a load of work their way). I mentioned the flywheel, they'll look at it and see
Brizee67
Incidentally, can the flywheel 'deglaze' itself after continuous use once a new clutch is fitted??
Justin.D
To be fair, it may have been slipping for a while, but I've only covered about 40 miles. I'll still get the lads to check it out though
Chilli Girl
Wish I had my "own boys" to do my car Justin, can you send a couple down south here! ;)
Justin.D
Quote from: Chilli Girl on October 31, 2018, 17:36
I'd love to Jane. Not sure they'd be pleased though, they like the East Midlands for some reason.
J03
Quote from: Justin.D on October 31, 2018, 07:03
Usually the included hardware isn't the best, personal preference would be to bin the LUK part & get a genuine replacement  ;)
Happy to be shot down.
But as far as I understand.
LUK are oem suppliers.
Quote from: Ardent on November  1, 2018, 18:03
I thought it was AISIN.
Maybe that's the gearboxes.
s12vea
Don't think it's Luk, They are great clutch kits
Ex TTE Turbo
Another one won't hurt  .....
Quote from: 1979scotte on November  1, 2018, 19:28
Will qualify my previous post.
Yes aisin will be stamped on it, but on closer inspection may reveal other names and part numbers as well.
