S2000 seats, stock seat sensors/SRS and seat height.
Started by Rockingdad, October 29, 2018, 10:15
Rockingdad
Morning all,
Toying with putting S2000 seats in but have a couple of questions regarding seat sensors and SRS.
Is the sensor in the stock seats linked to the SRS airbag systems firing? I.e. if it doesn't think anyone is sitting in it then it won't fire? Or is that just linked to the annoying seat belt reminder alarm?
Just double checking.
Also those with S2000 seats fitted, how is the height of the seat base compared to stock (I'm 6' 1") and is the base height adjustable? Also what are draughts lime with the mesh panel behind the head?
Many thanks
Rockingdad.
Sent from my SM-N910F using Tapatalk
2005 1E7 Silver with some mods.
MR2 How to vids and other cool content here:
www.youtube.com/Daddiaries
&The Other Stu has S2000 seats in his, he might be able to answer some of your fit and finish questions.
The Other Stu
As far as the SRS is concerned, the only lead going to the OEM seats is for the belt sensor - I doubt it's that clever.
I'm also 6'1" and shall we say stocky? (Fat). I get in the seats absolutely fine.
Again, like the OEM seats, they don't adjust any more than forward and back and the angle of the seat.
You need to fashion a bracket (I made mine out of some old OEM runners and an angle grinder). Otherwise, they share the same holes  :D
Rockingdad
Thanks for the responses guys, seems like this swop is a go then once I get some seats!!
Quote from: Call the midlife! on October 29, 2018, 12:04
Quote from: 1979scotte on October 29, 2018, 11:21
@The Other Stu
Better than my &The Other Stu..[emoji23]
Helping those less able than yourself is what this club is all about ;p
Quote from: 1979scotte on October 29, 2018, 12:53
@The Other Stu
Hahahahaha! I'm working outdoors and freezing my plums off! I had @ right before I discarded the original post to check if there were spaces between the words [emoji23]
Amen to that.
I proof read posts 3 times before pullingthe trigger. Only to find the glaring grimmitical errors a nano second after.
