sump plug sealing washer, one word reply needed
Started by 105e, November 8, 2018, 12:10
105e
Unless its in the bottom of the waste oil container,  i dont have one,  should i,  thanks
Yes.
@105e -It's possibly stuck onto the sump.
Nobody on here has done that before have they!
105e
Thank you,  i did check around the hole, didnt appear to be one there. I have been doing my own (and others) oil changes for 40 years, not exactly inexperienced..
Yes you should have one.
A 1/4 BSP Doughty is perfect.
105e
Havent any of those, will get some in, it was stuck on the sump, once it had stopped draining and i could remove the washing up bowl i use, and could get to it properly, i could prise it of..             EDIT  ordered 10, only £3.25  should keep me going for a while..
Quote from: Joesson on November  8, 2018, 12:21
Yes.
You'd have to be an absolute beginner to make that mistake...
105e
I noticed this on the www recently, although, like the sump plug washer
- no one has ever left the old one on- and doubled up on the washer,
a similar thing can apparantly happen to the oil filter.
-the old washer sticks to the housing-
and you inadvertantly double up with the new washer.
I understand that it really doen't work twice as well!
smarty72
Quote from: 105e on November  8, 2018, 13:15
Been doing your own oil changes for 40 years and still borrows the washing-up bowl [emoji1787]
current: Astral Black FL
Ex: Forest Green 2003.
Quote from: smarty72 on February 10, 2019, 00:22
I'd like to think that, like me, the washing up bowl that 105e uses is a long term borrow/ acquisition / stolen from the kitchen and doesn't double up for dish washing duties any more, well not unless it's had a good wipe round!
Quote from: Joesson on February 10, 2019, 10:17
To be fair at £3.25 for 10 washing up bowls I'd be classing them as disposable items, I pay a pound for 1 bowl at my local Poundstretcher. (Other discount shops are available).
Bossworld
https://www.amazon.co.uk/dp/B005F2ZMW4/ref=pe_3187911_185740111_TE_item
£6.99 when on offer.  After one too many an incident with a drip or spill on someone else's drive, decided I needed one of these last time out.
smarty72
Quote from: Call the midlife! on February 10, 2019, 10:26
Disposal drain pans - far too frivolous for me.  Anything more that 'free' is overpriced.
Been using this for many a year;
You may have read of references to Redex on here, particular from those old enough to remember these, they were on most petrol station forecourts when the motorist was served with petrol, the attendant would give you a "Shot" for 1d / 1 penny, ( an old one)
Petrol was about 2s/ 9d a Gallon!
https://www.ebay.com/itm/VINTAGE-AUTOMOBILIA-REDEX-DISPENSER-2609/302715533976?_trkparms=aid%3D333200%26algo%3DCOMP.MBE%26ao%3D1%26asc%3D20171012094517%26meid%3Dc83bd762d40c4a199a3a5dd7696bfca8%26pid%3D100008%26rk%3D4%26rkt%3D5%26sd%3D153369153011%26itm%3D302715533976&_trksid=p2047675.c100008.m2219
Found it while looking for the old oil cans in the above post.
Credit where due, often spoken of in less than favorable terms is Mr T your local Toyota dealer and service/ repair shop.
I made my annual visit/ pilgrimage ti my local Mr T to buy a sump plug waher and saw the same guy I have seen since I had my 2.
We had a pleasant chat as usual and he gave me the washer gratis, for free, no charge!
paulj
It's great when that happens. Many years ago I was having speedo problems on a Corolla Coupe, the issue was oil tracking up the speedo feed cable.  At the dealer the parts guy got out a cable replacement kit and started looking in the bag.  He said "you need a new one of those felt washers in the kit but we don't sell them separately". He then ripped open the bag and gave ithe washer to me!
Today
In the late 1980's
