Timing Marks
Started by a, November 9, 2018, 20:28
a
Fitting new timing chain kit camshaft timing marks spot on crankshaft 5 degrees out on cam chain cover mark(crankshaft pulley not on zero)??
chain on correct points on camshafts and crankshaft.
Any ideas please.
jonbill
a
Thanks for the reply jonbill
I think I have it!
Do you agree? That's if the photos have attached
a
a
jonbill
That all looks OK to me, one thing to check, I can't see the dimple on your inlet sprocket. Is it like this?
Quote from: jonbill on November 10, 2018, 11:26
Judging by the position of the cam lobes, I reckon the only place it can be is under the paint....
a
Quote from: Carolyn on November 10, 2018, 11:48
I bought the chain from Fensport a BGA kit. The vvt sprocket had no dimple so i counted 11 teeth inclusive anticlockwise from
the marked chain link (same as old vvt sprocket that had a dimple) and put a dot of white paint as marker on that tooth.
jonbill
Yep, I only asked because there's  something that looks a little suggestive of a dimple on the tooth below.
a
Thanks for your replies.
Up and running now. New cams,new timing chain kit all fitted all valve clearances adjusted and running sweet.No more rattles and tapping.
Quote from: shiny on November 16, 2018, 06:40
Which cams did you go for?
a
Cat stage 1 Just need to do a road test.
Quote from: shiny on November 16, 2018, 10:17
Cool! Would be grateful for you review on them when you're ready..
a
Will do after I give it a good run.
