Drain Hole Side Vent Hack
Started by Johnny5, November 11, 2018, 13:21
Johnny5
Quick tip for anyone unblocking the drain holes for the first time:
A combination of an old credit card and a pair of plastic bicycle tyre levers is excellent for prizing open the front edge of the side vent.   :)
Quote from: Johnny5 on November 11, 2018, 13:21
Good tip, if you're a keen cyclist...
One of these sets is pretty invaluable the further you go into DIY though.
Johnny5
Cool looking tools.  What are they called, and where can I get them?  Thanks
Just look on ebay/Amazon for car trim removal tools and pick the best for you, there's many different sets.
And not many wine tokens required.
Can be had for less than a tenner.  :D
Quote from: Ardent on November 11, 2018, 18:51
Indeed.!
Quote from: Johnny5 on November 11, 2018, 18:09
Ignore the screwdriver though obviously, that's just a screwdriver with some tape wrapped around it, for special reasons.
normanh
PVC curtain wire from inside works even better and no broken clips or possible scratched paintwork. Hand might get mucky but its so easy the wash it through. I have posted this so many times over the years now.
Norman
My 2 was supplied with some wire and an explanation of wiggling it throgh the drains to clear them.
I did remove the vents for the first time this year and found some " jellification" and yes, lost what I would describe as a spacer on one side, replaced it with the outer case and inner tube from a ball point pen, held together with a dob of hot melt adhesive.
