Rear Bumper
Started by Brizee67, November 15, 2018, 17:09
Brizee67
I've been prepping and painting my rear bumper over the last few weeks and thought I'd share my progress with you all.
Well first off I wanted to make good where I'd roughly cut my rear skirt to accommodate my Cobra Quads
I used a piece of aluminium mesh held in place with some P40 filler and then used fibre glass to line itI then blocked it roughly flat and then used filler to get it perfectly flatI did the same for the other sideI then touched up with fine filler any other areas that needed doing on the rest of the bumper and used red plastic primer. This was then wet sanded all over ready for paint
I then decided to paint it in two sections as I wanted to preserve the plastic trim which is between the rear skirt and the bumper and as I didn't have thin enough fine line masking tape; two sections it had to be.
Considering the time of year; I did well to get this looking as good as it does
Then today I sprayed the top half. This proved quite problematic as I had a slight silicone issue; even though I degreased it twice [emoji34]
I even took it into my garage to bake it to help with the curing as it was so cold
So all in all not a bad result. I will have to do some colour sanding to get rid of some of the bits of debris that has blown into the clear and then it should look great. Funnily enough I spent a lot of time and effort to make good the rough cut openings but when it's on the car you can't even see them...but it's been good fun and it's another panel complete [emoji1360]
dan944
Very nice!!
So when you going into business? I need mine doing ;)
Honda CR-V The Work Horse
Brizee67
Quote from: dan944 on November 15, 2018, 17:16
Very nice!!
I think it'll be a couple of years yet...I would love to do it professionally one day...I'm just looking at courses for next year [emoji4]
dan944
Quote from: Brizee67 on November 15, 2018, 17:18
Very nice!!
I've got a front and rear jdl bumper to work on...probably next year.
As well as lots of other bits that need spraying. Including my bonnet :/.
Brizee67
I'm looking to do all of the offside panels as well as the bonnet...it's actually exciting to decide what to do next...the bonnet doesn't really need doing yet but as it's a major panel I'll definitely be doing it at some point
I wish a had you patience.
Well done.
Brizee67
Quote from: 1979scotte on November 15, 2018, 17:33
Well done.
It has to be said I'm very patient and with this kind of work you definitely need lots of patience [emoji846]
Chilli Girl
Really great, yes very well done, credit to you for doing a brilliant job. I wouldn't have the patience!  :'(
Brizee67
Quote from: Chilli Girl on November 15, 2018, 18:49
Thank you Jane...it's not perfect but it's better than it was and I did it all by myself; so I'm well pleased...next panel!! [emoji16]
andyroo104
Looks great Brian, well done.
Sent from my SM-N960F using Tapatalk
Excellent work as usual.
Perhaps you need to put some vents in your bonnet, then you would need to paint it!
Brizee67
Quote from: Topdownman on November 16, 2018, 06:47
[emoji23][emoji23][emoji23]
Cracking results given your circumstances i.e. no booth.
Keep up the good work. :)
Very very nice indeed! I would be happy if I could just spray...
Brizee67
Quote from: StuC on November 16, 2018, 15:15
Thanks...I'm improving [emoji4]
Brizee67
Quote from: shnazzle on November 17, 2018, 09:02
I just wish I didn't have to spray outside in the cold wind [emoji53]
Quote from: Brizee67 on November 17, 2018, 11:43
No indeed. No idea how you managed to get such a good result. Mad skillzzz
Brizee67
Quote from: shnazzle on November 17, 2018, 12:44
[emoji2957]
