Need a VIN/serial from 2003
Started by Tem, August 4, 2003, 10:15
I'm after some 2003 parts, but my local dealer can't tell the difference between the models without VIN (or whatever it's called in UK  s:) :) s:) ). So anyone with a 2003...can I have yours?
It's just to check for the part numbers and nothing more. Won't do any harm to you or anything  s:) :) s:)
can't help with the VIN Tem, but what parts ae you after, I may have the numbers.
Quote from: "markiii"can't help with the VIN Tem, but what parts ae you after, I may have the numbers.
Pretty much everything  s:) :) s:)  Just wondering about the local prices for now.
Happen to have any part numbers for these?
Side intake covers
Rear grill inserts (+grill parts)
Front lights
Seats
Rear wheels
(I know the last two are probabyl way overpriced though  s:) :) s:)  )
I have the rear insert part numbers somewhere, I'll dig them out. I'm going to get a price for the wheel on Friday so should be able to get the number then. Incidentaly Japanparts are quoting £249 for the wheel.
In case anyone needs part numbers for the rear lights:
81553-17190 RH Housing
81563-17230 LH Housing
81551-17190 RH Lamp
81561-17230 LH Lamp
