Advice wanted.Track day car suspention settings
Started by KRAMSNEHPETS, January 17, 2019, 22:03
KRAMSNEHPETS
Track day car having some new adjustable rear track control cars and camber bolts fitted tomorrow in time for day out on Sat. Has BC coilovers. Looking for recommendations for alignment set up
2004 Red edition. 2ZZ engine with Rotrex 30 94 supercharger,90mm pulley. Link Storm ECU. Charge cooler. Custom Meggalian exhaust.Uprated fuel pump, regulator and rail.840 injectors.323 BHP at the hubs. Meistier coil overs. Matt under body brace. Front and rear, upper and lower braces,list goes on...
KRAMSNEHPETS
car is pre face lift running on stock 15" alloys with Nankang AR1 tyres
Based on allll the reading and talking I've been doing the past few days;
Front toe out a bit (make steering pointy)
Rear toe in a bit (stabilise rear and prevent oversteer)
-2 front camber (prevent oversteer)
-2 rear camber (grip and bit of understeer)
Rear damping lower than front (to taste)
That's where I'm going next.
No idea of your location.
But. I would suggest a visit to wheels in motion and tell them what you want.
They will set it up accordingly, as much as the set up will allow.
I cannot talk this degree or that. But if you say you want a track monster. They will dial in accordingly.
james_ly
I was told by someone on the facebook page that some of the racers just run the standard geo settings. My car just has Meisters slapped on and it genuinely handles really well!
MR2 gone<br />GT86
Kaveney
It was done late last year along with the 2ZZ conversion so don't know yet but if feels much better set up than it was even on the road .
Quote from: shnazzle on January 18, 2019, 10:57
Quote from: Kaveney on January 18, 2019, 10:45
Rogue did me the below set up .
https://thumbsnap.com/s/cObx6nQW.jpg[/img]|https://thumbsnap.com/cObx6nQW]
Lines up with my thoughts above. Are yoy happy with that?
neogeo13
Get the coilover to the hight you want and its very important to get the car corner balanced.
Dont skimp and do alignment only.
I started with factory settting added 1 deg camber front and rear.
Be like water...
YouTube channel-mr2 screaming chicken
2zz-with alot of other bits.
FB group- Toyota on track
KRAMSNEHPETS
arms didnt get fitted,,, out tomorrow on standard setting with which to be honest the car felt great on last time out. will try some of the advised setting next time, thanks for all the info
Dudi
Quote from: neogeo13 on January 18, 2019, 16:30
Nail on the head, corner balancing made the world of difference to the handling.
