PFL Wheels and tyre size
Started by Kaveney, January 30, 2019, 09:12
Kaveney
Good Morning all
Does anyone know if you could use the PFL 15 inch rear wheels with 225/45/15 tyres or will they be too wide to fit .
The rear PFL wheel is the below spec
Rear Wheels
Width 15″ x 6.5″
Offset = et45
PCD = 4 x 100
The FL rear wheel is the below spec and is fine with 224/45/16 .
Rear Wheels
Width 16″ x 7″
Offset = et45
PCD = 4 x 100
Rim   min   optimal             max
5,0   155   165 or 175   185
5,5   165   175 or 185   195
6,0   175   185 or 195   205
6,5   185   195 or 205   215
7,0   195   205 or 215   225
7,5   205   215 or 225   235
8,0   215   225 or 235   245
8,5   225   235 or 245   255
Easier stil:
https://www.tyresizecalculator.com/tyre-wheel-calculators/tyre-size-for-rim-size-width-calculator
Kaveney
Ok so 215 is the max it looks like .
Regards
james_ly
I sold my facelift wheels for £50, so it should be easy to get some cheap.
MR2 gone<br />GT86
Kaveney
Just thinking of going to PFL 15 inch in 195/50/15 front and 205/50/15 rear .
The set up I have at the moment is 195/50/15 front and 225/45/16 rear .
Car is for track work only .
Quote from: james_ly on January 31, 2019, 13:35
james_ly
The 15" wheel is a bit lighter, but narrower tyre gives less grip at the rear, so it really depends what you want to achieve. I like the handling with less grip personally, but I'm weird and run cheap tyres on purpose :)
MR2 gone<br />GT86
