Garage recommendations for an engine rebuild and install
Started by Dudi, February 6, 2019, 16:51
Dudi
Apart from Rogue Motorsport any other recommendation for an engine rebuild and install (2ZZ or K20 undecided at present).
Location flexible from Manchester, Midlands, South Wales , South West or towards London.
You could just buy a rebuilt one off mag engines and then fit it? (2zz)
Alternatively you could just buy Joecools (2zz)car which is effectively a turnkey solution and save yourself an awful load of money, time and effort..
Dudi
I've blown the 2ZZ in my track car and looking to get an uprated (uprated bearing, valves, oil pump gears and possibly cams) 2zz or just going all out and K20 it. Ideally looking for a drive in and out solution as I'm just completely flat out with work at the moment.
Me and a good friends pretty much built the car so I have no aversion to a set of spanners but the time just isn't there.
Quite a few people still swear by Patrick Chambers down south. Headcase on here
He's done more 2zz conversions than I care to count.
KRAMSNEHPETS
2004 Red edition. 2ZZ engine with Rotrex 30 94 supercharger,90mm pulley. Link Storm ECU. Charge cooler. Custom Meggalian exhaust.Uprated fuel pump, regulator and rail.840 injectors.323 BHP at the hubs. Meistier coil overs. Matt under body brace. Front and rear, upper and lower braces,list goes on...
Dudi
It's a shame Patrick is 8 hours away from me, otherwise he seems to be a good option.
MannyUK
I gave my mechanic a box of 2zz engine parts from an engine which i had dismantled and didnt have the skill to rebuild.  He rebuilt it all back up, installed into my mr2, did all the custom work as well.
Simon @ YVS in Sherburn in Elmet nr Selby North Yorkshire.  His garage could do with a clear out and a tidy but his knowledge on MR2/jap cars has never let me down.  He rebuilt my mk2 Mr2 upto 350BHP on a limited budget a few years ago.  Good workmanship and he really enjoys his work.
http://www.yvsperformance.com/contact.html
Buttery biscuit base
brettfield999
Quote from: KRAMSNEHPETS on February  6, 2019, 22:00
Patrick chambers is your man
+2 did mine, v reasonable cost too
Sent from my BBB100-2 using Tapatalk
[strike]2000 Blue PFL MR2 Roadster with 187K, engine blown[/strike]<br />[strike]2000 Blue MRS, 80K[/strike]<br />[strike]2001 Blue PFL MR2 Roadster 131K, 2ZZ,[/strike]<br />[strike]2003 Silver FL MR2 Roadster with 81K now daily driver, 2ZZ by Headcase[/strike]
