mph per 1000 revs in sixth
Started by 105e, February 21, 2019, 15:42
105e
As title, does anyone know the exact figure?,  obviously i have a rough figure using rev counter/speedo.  thank you..
stewart@boro
I did have a spreadsheet with all gear ratios and specs.
Speed to rpm can vary depending on factors such as wheel diametre, tyre profile etc.
With a standard FL set up I think it worked out at 404.7 rpm per 10mph
Mind you this gives a theoretical top speed at 6500rpm of 162mph :)
TF 160 TTE exhaust and style bar and other shiny bits.
Replaced by an Abarth 124 Spider
stewart@boro
I will see if I can find the file when I get home, unless anyone else can help
pauls0212
the 5 speed is 146 @ 6500 revs
red 2003 standard so far
