Plug and play Ecu's piggy back and standalone
Started by Gaz2405, March 9, 2019, 17:59
Gaz2405
Seem to be struggling to come up with any answers on this.
Who in the UK supplies plug and play Ecu's that maintain original dash functions and what other options are available.
I'm midway through collecting parts for a 1zz turbo build.
ECU options (plug and play only) :
Aem ems4
Greddy emanage ultimate
Apexi PFC
Anyothers???
Also people's experiences with any.
I'm aware of the group buy on ecu master,  ut want to look at the plug and play to save having to tailor the car about. I would also consider though being a test mule for adaptronic or similar to create a pnp loom as the car is a weekend car.
Gary
Initial answer would be that even "plug and play" really needs a professional tune to get the best from your individual setup so I would still consider the Ecumaster in with the rest.
All piggyback keep stock functions. Most have plug/play.
ECUMaster comes with plug/play harness and maintains stock functions
Dastek unichip q+ is most feature-rich piggy, if you can find someone to map it
Link is most expensive (depending on version) but doesn't do nay more than you'd actually need over the ecumaster
Emanage blue waste of time
Emanage ultimate, surprisingly good. Harness is very expensive though
Gaz2405
Oh yes, Fully aware that it will need dyno time and a full tune.
I'm just wanting to keep the wiring as stock as possible and forgo the need to splice loom etc.
Having done it in the past is prefer if a plug and play option is available.
If you want a piggyback then its the ultimate but you don't want a piggyback.
Do it once do it right get a standalone which whilst the group buy is valid makes the ecumaster impossible to beat.
Gaz2405
Perfect wasn't aware the EMU was plug and play.
Those who have had it fitted is it fitted on site or will they post with a base map?
Quote from: Gaz2405 on March  9, 2019, 18:38
Whatever you want. As long as you pay :)
Could even ask for a base map
Fit your turbo bits.
Trailer to RRR.
Then they fit and map.
Thats what I would do.
dan944
Agree. Let Greg map it, the guy is a genius.
You could drive it there if you stay outta boost/ keep the wastegate open. Just make sure you have somewhere to plug in the wideband sensor.
Honda CR-V The Work Horse
Gaz2405
I'm going to drop Greg an email on Monday.
Plan A:  Order loom, ECU (with base map) install at home, drive to Greg out of boost, either wastegate held open/boost pipe disconnected/trail or.
Plan B: Install turbo kit trailor to Greg and have it fitted and mapped.
Only reservation on Plan B is getting booked in and that date holding and not being put back, after reading through the initial issues people have had.
Cheers guys
You're not wrong about the issues with plan B, but now I think it's more the duration of time it takes vs the booking date.
He takes his time and doesn't cut corners. So drop it off early AM and expect to be there until 6pm.
There's nothing wrong with plan A to be fair. As long as you make sure everything is plumbed in before you get there. Order the intake air temp and lsu 4.9 wideband before you get there and put them in. This obviously requires wires to be run into the engine bay. Just for those two though.
So that's the only issue I can think of; if you get the harness sent to you with the wiring and connectors already attached for the wideband and IAT, how are you going to get it into your engine bay?
Sliding a plain wire through the grommet is easy. Wiring with a connector is another matter.
And the ecu won't run without these inputs.
Quote from: Gaz2405 on March 10, 2019, 09:04
Cheers guys
I'm not far from RRR.  You're welcome to use my place as a 'staging post' and somewhere to hang out while the job is done.
dan944
Quote from: shnazzle on March 10, 2019, 09:12
Greg is to clever for this. [emoji1787]
He used the wires for the O2 sensors that are already in place on mine. Keeps it neat as well.
Gaz2405
Thanks guys, yeah I think I'm going to go with plan A. All sensors are on order, I've no issue with fishing wires through bulk heads or having to snip a couple and rejoin.
I've built a few cars in the past and most recently our adventure style campervan, which required a fair few wires! Full solar install, fully off grid.
