Boost controller
Started by a, April 20, 2019, 07:54
a
What is the best to use or will the wastegate work on its own?
Only after low boost nothing big.
s12vea
Waste gate pressure will be fine for low boost setups.
It will feel fast enough over stock, but with proper boost control running high boost its a different level of crazy fast
Another one won't hurt  .....
dan944
Agreed.
At wastegate pressure Greg squeezed 180bhp out of mine at the wheels. I didn't get to drive it like this but I imagine it was pretty mental still.
But if you want a boost controller I used a MAC 3 port solenoid. About £40 most places. Very highly rated from what I gather.
Honda CR-V The Work Horse
a
Thanks for the replies.
For the controller, the Apexi Avcr, despite its age, is still regarded as one of the best. Matched with the MAC solenoid Dan mentioned. Can't get much better without going standalone.
You can pick them up 2nd hand for a reasonable price
a
Quote from: shnazzle on April 21, 2019, 08:03
I take it this all connects into the power fc? Although I will run it on the wastegate to start with. Thanks shnazzle
Quote from: shiny on April 21, 2019, 10:54
Apexi Power FC for 1zz won't do boost control as far as I can remember.
It's plug and play convenience means you loose the adaptability.
I have put a ´manual boost control´ in several of my pre-all-electronically-managed turbo diesel engined cars.
A simple adjustable valve in the pressure line to the wastegate.
A turbo pressure meter in the dash and have fun.
Oh and adjust the max of the diesel pump of course.
And turn it all back again once a year for the periodic inspection particles test....
Alas those days have gone now with the electronically controlled set parameters.
Went out this morning giving my son driving lessons on the local industrial estate (the test track :-) ) in his moms car. A modern 4x4 diesel. It has anti-fun traction control which is effectively a anti-dad drift control  >:D
There is NO WAY to do anything fun to it. The moment you try trick one sensor, you are outside the parameters of the others and the system goes into limp home at best, shut down at worst.
My son hás to learn to drive a moder stick shift car so it has to be done but I am affraid he is genetically burdened; he só much prefers his electronics-free, basically even electrics-free 35 y.o. DAF variomatic.
Quote from: 1979scotte on April 21, 2019, 10:57
According to the specs all the Apexi power fcs will control boost, with the appropriate additional sensors etc.
Nope it's a standalone unit. It's not an ECU.
Its sole purpose is to control boost, but it does it rather intelligently with a heap of settings.
It was the option I was going to go for before we decided to just go for the standalone ecu
Quote from: Call the midlife! on April 21, 2019, 13:03
I don't believe the additional sensor work with it.
I looked this up a while ago Apexi don't list a boost control kit for the 1zz power FC.
Perhaps there is a work around.
As I have said before the Apexi has has it day and there are better options.
Scott is 100% right.
New PFC is 650, boost controller 200, sensors another 150, mapping 500.
....oooooorrrr 1200 for a fully custom tuned standalone with all of the above.
Bit of a no brainer.
Quote from: 1979scotte on April 21, 2019, 13:37
Yeah, to be fair the specs are pretty generic for the whole range, it's not something I needed to worry about when I got the Apexi as I'll never be boosting this particular engine.
It's pretty old now (read: cheap), but I found the HKS EVC 5 an excellent method of controlling boost.
As to your question regarding wastegate pressure, it depends on the spring rating of the actuator. Different actuators can have different wastegate opening pressures, which is dependent on the rating of the spring.
There is no answer until you find the rating of your actuator/spring.
Essex2Visuvesi
The Apexi can control Boost if you use the FC Hako and FC-Edit Software
But in all honesty if you're going boosted there are much better alternatives now
a
Quote from: Alex Knight on April 24, 2019, 10:24
The actuator has a white spring fitted which I believe is quite low.
Essex2Visuvesi
You're welcome to borrow my pressure tester.  Will be able to test the actuator pressure and find out the weight of the spring
I'm over near Witham so not far up the road
A white spring is something like 0.3-0.5 Bar (4.5-7PSI) depending on the brand of actuator
a
Quote from: Essex2Visuvesi on April 27, 2019, 10:31
Thanks for that offer. The turbo is not on the car yet still collecting info.The actuator is an Arashi.
Project so far....The power fc is already running the car nicely (N/A).
Essex2Visuvesi
That makes lie easy, we just need to connect a hose from the actuator to the pressure tester
mine looks a bit like this one but can do both positive and negative pressure
a
I have that kit I will try it Cheers
Essex2Visuvesi
Quote from: shiny on April 27, 2019, 16:07
Which one do you have? some only do vacuum
a
Does yours just have one gauge?
a
Just had a look at my ebay purchases and I bought the same as yours just need to find it now.
I am going to buy an AEM in cab boost gauge (not tru boost) just to keep an eye on.
Just sayin... Sure you bought the right tool...
